:( dryer runs fine if it wasn,t for the noise. it rumble and sqeaks as the drum turns vibrating the whole dryer. sound is coming from the back of the dryer and drum seem to be unbalanced (shifting up and down). any help would be welcome.
Groups: Expert
Originally Posted by: hardcase  :( dryer runs fine if it wasn,t for the noise. it rumble and sqeaks as the drum turns vibrating the whole dryer. sound is coming from the back of the dryer and drum seem to be unbalanced (shifting up and down). any help would be welcome. It sounds like one or both of your rear rollers is having a problem. I like to replace them both at the same time. Here's the Part number: AP4008534
