clothes have been getting stuck inside dryer in the front, and causing marks on clothes. The tumbler does seem to rock a bit, belt is okay but wondering about the bearing kit for back of tumbler. Please help, thanks
Sounds like the upper and the lower felts (#21 & #22 on the diagram) are worn out. It is a good idea to replace the rear bearing as well. - The upper felt glide assembly Part number: AP2150497
