The hard encasement panel that holds the drum sliders in place and serves as a cover for the lamp's electrical wires broke(upper semi circular protective panel). This is located inside the upper portion of my dryer door on my front load dryer(DBVH512EFWW). I need to replace the top plate but I cannot find the part number or a picture of it anywhere in the schematics. I am also having to replace the drum sliders and not too sure about the felt ring. Does anyone know what this hard semi circular plate is called/part #? Can you direct me on everthing I need buy to replace the drum sliders? Any help will be greatly appreciated. Also the number embossed inside the broken panel is #2 212D1107, just in case this may provide any help determining exactly what part this is.
Groups: Expert
Originally Posted by: glassmigrations  The hard encasement panel that holds the drum sliders in place and serves as a cover for the lamp's electrical wires broke(upper semi circular protective panel). This is located inside the upper portion of my dryer door on my front load dryer(DBVH512EFWW). I need to replace the top plate but I cannot find the part number or a picture of it anywhere in the schematics. I am also having to replace the drum sliders and not too sure about the felt ring. Does anyone know what this hard semi circular plate is called/part #? Can you direct me on everthing I need buy to replace the drum sliders? Any help will be greatly appreciated. Also the number embossed inside the broken panel is #2 212D1107, just in case this may provide any help determining exactly what part this is. Check out this page. Front panel replacement parts for General Electric DBVH512EF0WW Electric dryer | AppliancePartsPros.comI think the parts you are talking about are 312, 313, 315, and 316.
I appreciate your help and did confirm the parts you had listed against the ones I thought might be the ones I needed. Wish me luck on the repair. :confused:
Groups: Expert
Good luck! But you won't need it. Its pretty straight forward. You'll be done in no time.
