I've fixed a sqeeky noise several years ago by replacing the blower wheel, the lack of heat is new to me. Any suggestions? Thanks ahead of time
First check to make sure you have 120v to each side of the connection block. If you have power to only one side, the machine will run but not heat.
If that checks out, check the thermostats for continuity and the heating element for continuity.
I think you will find your problem from one of those checks.
