slave2christ
#1 Posted : Wednesday, July 28, 2010 1:42:04 PM(UTC)
slave2christ
I changed the lower element last fall. Worked like a champ until the last few weeks. Now the oven (most of the time) takes a long time to pre-heat. Even if I use the broiler to pre-heat and set the temp to where I won't, it is a while before it will hold at that temp.
Is this a problem with the element? Or is it possible that it has come loose a little on my previous install? I am not afraid to replace/repair, with some advice, but I am the handiest of men at this.
#2 Posted : Wednesday, July 28, 2010 4:31:05 PM(UTC)
Does the element get red hot when in use?
If it does not, check the element for continuity and make sure the wires to the element are not broken.
Here are the breakdown diagrams and Replacement parts for General Electric JBP64WB4WW Electric range | AppliancePartsPros.com
slave2christ
#3 Posted : Wednesday, July 28, 2010 4:53:18 PM(UTC)
slave2christ
Thanks. I'll investigate and let you know.
slave2christ
#4 Posted : Thursday, July 29, 2010 4:49:09 PM(UTC)
slave2christ
Thanks! Once I opened up the back, it was obvious what the problem was. The connector was fried.
Herb
#5 Posted : Thursday, July 29, 2010 5:22:35 PM(UTC)
You are welcome. I'm glad it was that simple.
