I changed the lower element last fall. Worked like a champ until the last few weeks. Now the oven (most of the time) takes a long time to pre-heat. Even if I use the broiler to pre-heat and set the temp to where I won't, it is a while before it will hold at that temp.
Is this a problem with the element? Or is it possible that it has come loose a little on my previous install? I am not afraid to replace/repair, with some advice, but I am the handiest of men at this.
Thanks. I'll investigate and let you know.
Thanks! Once I opened up the back, it was obvious what the problem was. The connector was fried.
Herb
You are welcome. I'm glad it was that simple.
