My 10 yr old whirlpool ****** dryer has no heat and just spins I changed the three thermastates its heats up then go's cold
What is the complete model number of the dryer?
its LGR4634JQ2 hope you can help.
If the igniter glows and lights up the flame at the first time, but later the igniter goes on and off without the flame, replace the gas valve coils. - The coil kit Part number: AP3094251
will check it out thanks ,will get back to you :)
