Tom Smith
#1 Posted : Wednesday, July 28, 2010 12:22:01 PM(UTC)
Tom Smith
Dryer Get Real Hot Even On The Delicates Cycle. I Have Replaced Two Thermostats On The Back Side Of The Dryer. The Part Numbers Are, 134120900(thermal Limiter), And 103281113(thermostat). Can You Help Me Figure Out What I Need To Do?
Thank You,
Tom Smith:(
#2 Posted : Wednesday, July 28, 2010 2:37:31 PM(UTC)
Hi Tom,
Very likely the problem is an obstructed air flow, which causing the dryer to overheat. Make sure the dryer exhaust line is clean all the way through its outlet and there is nothing wrong with the dryer blower wheel. It's also a good idea to take the dryer apart and clean everything from lint.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FSE747GES1 Frg(v0) / Electric Dryer | AppliancePartsPros.com
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
