Amy Dolsen
#1 Posted : Monday, July 26, 2010 3:55:46 PM(UTC)
Amy Dolsen
worked fine lastnight, will not start now. replaced timer several months ago, have checked breaker and have power up to timer and start switch
ThatGuy
#2 Posted : Wednesday, July 28, 2010 3:16:19 AM(UTC)
ThatGuy
Groups: Expert
United States
Check the door switch and see if its clicking and if it has continuity.
revndave
#3 Posted : Wednesday, July 28, 2010 7:06:23 AM(UTC)
revndave
I would go with door switch also.
Amy Dolsen
#4 Posted : Wednesday, July 28, 2010 3:07:34 PM(UTC)
Amy Dolsen
replaced door switch today as well as push start button and still no go
already replaced timer not to long ago.
revndave
#5 Posted : Wednesday, July 28, 2010 3:54:53 PM(UTC)
revndave
Does it have 220/240volts at wall plug??
#6 Posted : Wednesday, July 28, 2010 5:38:22 PM(UTC)
Remove the rear panel and check the thermal fuse (#23 on the diagram) for continuity.
- The thermal fuse Part number: AP3132867
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
