evae
#1 Posted : Monday, July 26, 2010 7:13:20 AM(UTC)
evae
My ice dispenser bucket will not go back, do i need to adjust anything?
ee
Joe / APP Team
#2 Posted : Monday, July 26, 2010 8:16:14 AM(UTC)
Joe / APP Team
ee
A couple of easy quick checks first.
Make sure there are no spilt cubes between the back side of the bin and the auger motor or ,drive fork.
Make sure the auger drive hub (in the back if the bin) aligns properly with the drive fork of the auger motor(back wall area). also check and make sure you have no obstructions or broken pieces on the track assembly(s)that the bin slides in / out on .
have a nice day
evae
#3 Posted : Monday, July 26, 2010 10:58:13 AM(UTC)
evae
I suspect it is the alignment, but how do i check/know that? what should it look out properly aligned?
thank you very much
e aligns properly with the drive fork of the auger motor(back wall area). also check and make sure you have no obstructions or broken pieces on the
Read more: http://forum.appliancepartspros...post245562#ixzz0uof8hhtY
http://forum.appliancepartspros.com
Joe / APP Team
#4 Posted : Monday, July 26, 2010 12:35:43 PM(UTC)
Joe / APP Team
thank you very much
When you removed the bin to clean, used the cubes to fill another container or for any reason, if the auger turned, while doing this you may have knocked the auger drivr hub and it is not aligned to the drive arms on the motor assembly the arms must fit in the opening on the drive hub of the bin. You will need to look and guess the alignment of the fork tongs and opening in the drive hub.
If your bin slide retainers were cracked, broken, loose. or if there was debris in the track that you did not see when you removed the bin , it wont alighn properly and seat when you reinsert the bin.
evae
#5 Posted : Wednesday, August 4, 2010 11:10:40 AM(UTC)
evae
I thank you for your reply, now I know what needs to happen! I have been trying..... is there any sketch for people who still can not fit it correctly?
Joe / APP Team
#6 Posted : Wednesday, August 4, 2010 1:12:46 PM(UTC)
Joe / APP Team
Glad you figured it out.
To my knowledge, no there is no sketch or instruction sheet for re installing the bin, Sorry. :)
Guest
#7 Posted : Wednesday, June 21, 2023 4:57:46 AM(UTC)
Guest
Rank: Guest
United States
My bin aligns on the shaft but will not seat properly onto the driver hub. There are no obstructions anywhere. It sits on the drive hub but will not go down any further
Guest
#8 Posted : Sunday, April 28, 2024 7:18:04 PM(UTC)
Guest
Rank: Guest
United States
I'm having that same problem.
