coachbrady
#1 Posted : Monday, July 12, 2010 6:28:40 PM(UTC)
coachbrady
My dishwasher will not drain. I have tricked the unit into thinking the front is closed and i can see water being moved around in the bottom of the tub when i put it in drain mode. I have a repair man out, he spent VERY little time and said my "pump" was bad...$ 350.00 repair. Does it seem resaonable that i might have a pump (i am assuming drain pump) bad and still see water moving when in drain mode? I have found a drain pump from your company for the great price of $ 59.42, now that is the kind of markup that someone might get rich from if i were to hire the repair service. I cant imagine it being an hour in repair time. What are the common causes of water standing?
Applianceaid
#2 Posted : Wednesday, March 2, 2011 10:55:06 PM(UTC)
Applianceaid
Most common issue is clogged drain hose or candy cane the part that connects to the end of the drain hose.
Here is a video that explains how to access the drain motor and clean it out more often than not that's all that needs to be done.
Bosch DW Repair Video
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
Bosch dishwasher won't drain (Dishwasher Repair)
by Debbc 4/25/2009 8:25:42 AM(UTC)
by frennings 12/23/2008 2:37:08 PM(UTC)
Bosch dishwasher won't drain after installing new garbage disposal (Dishwasher Repair)
by madden611 11/25/2008 4:05:12 PM(UTC)
Bosch dishwasher won't drain, power surge problems? (Dishwasher Repair)
by vcalkins 8/16/2008 8:41:02 AM(UTC)
by downtube 7/1/2008 4:29:01 PM(UTC)
Bosch Dishwasher won't drain (Dishwasher Repair)
by Little Lost one 6/12/2008 11:30:14 AM(UTC)
by reisman 12/24/2007 7:31:35 PM(UTC)
Bosch Dishwasher Won't Drain (Dishwasher Repair)
by jshoe01 9/5/2007 5:56:15 PM(UTC)
