Followed trouble shooting guide supplied with dryer and tested: Thermistor (good), Thermal Fuse (good), replaced Hight Limit Thermostat, tested both coils, main coil (PN AP3041626) tested higher resistance than guide @ 1310 ohms so I replaced. Still no heat. New main coil had about same resistance, so that was not the problem. This is all the test recommended in the guide. What other parts or test can I perform? I conducted the automated diagnostic test and all appeared to be good.
Just checked ignitor and it is not getting hot, resistance measures 75 ohms and input power measures 37 volts AC. Any suggestions?
