jeanpier
#1 Posted : 17 years ago
jeanpier
I have Whirlpool Oven RBS305PDQ4 and the oven door will not stay closed during baking/broiling. What parts do I need to fix this? How do I access parts to replace them?
#2 Posted : 17 years ago
This is very hard to diagnose problem due to many different parts involved. The best thing is to call a Whirlpool authorized technician.
jeanpier
#3 Posted : 17 years ago
jeanpier
Thank you, Gene. I assume that the hinges and springs are the problem. Are these difficult to replace? Where can I find a diagram?
If you think this is too tricky for average homeowner, please let me know and I will call repair person.
#4 Posted : 17 years ago
Replacing the door hinges could solve the problem and could not. If you would like to try, these parts are not too difficult to replace yourself.
Remove the door from the oven as described in the "Use and Care manual" (page 13). The part number for the door removal pins is AP3066060
Place the door on a flat surface with the door handle facing down and remove the screws holding the inner door panel. Remove the inner door panel.
- The part number for the door hinge assembly (both door hinges are identical) is AP3080711
Here are the break down diagrams for the Whirlpool oven Model RBS305PDQ4
jeanpier
#5 Posted : 17 years ago
jeanpier
Gene,Thanks for much for your helpful reply--I will give this a try. Again, thank you for your generosity.
#6 Posted : 17 years ago
You're welcome. Good luck.
jeanpier
#7 Posted : 17 years ago
jeanpier
Gene, I completed replacement of the hinges--it was quite easy with your guidance and it solved my problem. The oven door now closes securely.
For those who may wish to try this also, I probably did not need to order the pins as they came with the hinges but I certainly didn't need to order 2 sets. A small price to pay for an oven door that works!
Thanks again.
JP
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 5 years ago
Oven door won't close tightly-has a gap (Oven Repair (including Ranges and Cooktops))
by gloverzoo 10 years ago
Jenn-Aire Oven door won't Close (Oven Repair (including Ranges and Cooktops))
by jgmann 10 years ago
GE Profile Oven Door won't close (Oven Repair (including Ranges and Cooktops))
by TeriT 11 years ago
Thermador oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by fixitboy 11 years ago
Kenmore Oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by ritarandall 13 years ago
Oven door won't close (Oven Repair (including Ranges and Cooktops))
by DottieH 13 years ago
Oven door won't close all the way... (Oven Repair (including Ranges and Cooktops))
by RN2010 14 years ago
Oven door won't close right (Oven Repair (including Ranges and Cooktops))
by tsimonsen 15 years ago
by mhamil1017 15 years ago
Oven Door Won't Close!!! (Oven Repair (including Ranges and Cooktops))
by glenardee 16 years ago
by hamconsulting 17 years ago
Viking oven door won't close (Oven Repair (including Ranges and Cooktops))
by McDoo 17 years ago
