We have a GE jgsp28sek1ss range. The left side burners light fine -- spark ignition. The two on the right will not light. They are sealed style burners. I can see spark in the same way on all 4 burners. The right side burners will light with a match and seem to be burning a full strength.
Today I attempted to reset the burner elements, check that the ignition ports were clear, confirm that there was spark at each burner and get all of the burners working. In the end the two front burners work as they should, but now the back two burners do not light.
What is the issue?
