I just bought a house that has the above oven in it.
The digital display does not work although some of the touch pads do work. The Baking/Broiling etc do not work.
If I buy the control board and replace it, will that solve the problems and how hard is it to replace. From the diagram it looks like it's just a couple of ribbon connections.
Quote:The digital display does not work although some of the touch pads do work. You might have several problems, the electronic control and also the keypad. I don't know that just the control panel display failing would prevent some of the keyboard keys from functioning. LINK > Jenn-Air WW27430W Electronic ControlLINK > Jenn-Air WW27430W Control KeypadQuote:If I buy the control board and replace it, will that solve the problems I would think replacing the control should correct the display problem. Quote:how hard is it to replace. Once you get to it, it shouldn't be that difficult. I do not know exactly what is involved in accessing it on your model although that too isn't usually that difficult on most models. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
Thank you so much for your help. I had read that the lack of display in the control panel is quite a common problem with the jennair ww27430w. The guy on the Jennair help line told me that these ovens only have a life span of 10 to 13 years and told me that I would have to spend $3000 to buy a new one. This was very easy to fix and it only cost $180..or so. Now I just need to find the owners manual online. Thanks again.
Quote:I had read that the lack of display in the control panel is quite a common problem with the jennair ww27430w. It is a common failure on all brands and models of appliances that use such controls... unfortunately. :rolleyes: Quote:Now I just need to find the owners manual online. LINK > Jenn-Air WW27430W Product Literature Quote:This was very easy to fix Glad to hear it. Thanks for the follow up. Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~
I had been searching for that for hours and couldn't find it. One more thing, is there a way to replace the facade of that oven with Stainless Steel?
