My evaporator motor is not getting power consistantly causing top to get warm. The coils will freeze up just a little when it does that. No total blockage of cooling unit. I can unplug it and let it defrost but sometimes still no power to evap unit. I have checked the motor and it always runs fine when wired directly. I will just about break down and schedule a repair from Sears and suddenly it will start working by itself after sitting an hour or two. This has happened three times this year. Any ideas?
your refrigerator goes into defrost mode about once every 8 hr.s for about 20 min. when in defrost mode there is no power going to the fans intill it come's out of defrost mode.
