I have a Frigidaire gallery dishwasher model FGHD2465NB1A that has worked great until very recently. After a storm, the display on the front of the dishwasher displays code A. I Flipped the breaker and left the power off for at least 15 minutes. When I powered it back on, it had a PF code but as soon as I opened it, it went back to the code A. None of the buttons on the control panel do anything. It Continues to have the A error. Does this sound like a control panel issue or a console issue or something else?
Joined: 5/12/2024(UTC) Posts: 0  Location: Ontario Was thanked: 10 time(s) in 10 post(s)
Hi, I have not seen an fault code "A" before. I found this in the use and care manual. A copy: In the unlikely event the dishwasher malfunctions, the indicator may display one of the following codes "Er", "uF", "uo", or "CE". If one of these codes are displayed contact the Frigidaire Customer Care Center at 1- 800-944-9044 They will be able to provide assistance in troubleshooting the problem and/or locating an authorized service technician, if needed. Maybe they can offer some tips into this A code. I forgot, PF is just Power Failure. jeff sr. Edited by user Thursday, June 27, 2024 7:13:39 PM(UTC)
| Reason: Not specified |
 1 user thanked applianceaid1 for this useful post.
