Washing machine will not spin during rinse cycle
We changed the actuator, problem not solved. The machine will fill wash spin fill drain and stop. It does seem on some of the settings the washer starts to fill and then empties itself while it’s in the soap mode so it never gets to wash. If I take Knob after it stops change it to drain and spin it works per Fine to finish the cycle Won’t do that on it’s own
