astringfield
#1 Posted : Wednesday, December 29, 2021 4:58:36 AM(UTC)
astringfield
This is a free standing dual oven, 6 burner natural gas range with griddle ZGP486LDR4SS. While cooking using the convection mode the unit shut down around 3 times with an F9 error code. The faults came in at different times - not immediately. I've read this is an oven door lock during oven cleaning. I shut power off for a few minutes and reapplied power. What I saw flash momentarily on the display when it was powered up were these four codes 1) 0297 Clean & Probe, 2) 72EE 1 clean, probe, set, 3) 1E1E Clean, time, probe and the last 4) CECE Clean, probe, 0F & a lock icon. I restarted the oven with no problem. Oven cleaning was not being used when the F9 error code came in and I've never used it. The door was not locked. I pulled the door lock out and applied voltage to the coil, the motor rotated and the contacts on the auxiliary/micro switches changed state from open to close and vice versa. I have not attempted to use the oven since this problem occurred. Any thoughts or advice appreciated, Thanks
ohm
#2 Posted : Wednesday, January 12, 2022 6:36:37 AM(UTC)
ohm
Was thanked: 11 time(s) in 10 post(s)
F9 Read this service manual: http://www.uncleharrywiz...16-monogram-prof-gas.pdf
-F9- Cooling fan stalls or other cause of open sail switch.
If repeated, replace.
Suspect stalled cooling fan or air- flow to control area.
Edited by user Wednesday, January 12, 2022 6:38:53 AM(UTC)  | Reason: Not specified
