Chops
#1 Posted : Saturday, January 16, 2021 8:51:39 AM(UTC)
Chops
United States
I'm puzzled by the fact that the washer worked perfectly yesterday and today won't fill. There are no fault codes...it hums for a few seconds but will not fill. I tried Hot and Cold settings, checked the strainer fittings on the rear inlet hose bibs with no luck. I'm leaning towards possibly the motherboard as opposed to the single Hot and 4 gang Cold valves both failing at the same time. Any thoughts or easy troubleshoot solutions? I have a VTVM and know how to use it! I also have the Tech Manual attached to the back of the unit.
Thanks, Chops
