I have a new fridge that is fine cooling down quickly. At some point over night the GFI is blown on the outlet.
I have tried to remove possible causes. Switched outlets to another breaker/GFI. I tested the the manual defrost to see if that was what might be causing it. Result was completed defrost cycle with no breaker issue.
I am not sure how to figure out other cycles might be causing this issue.
Any ideas?
Refrigerator is rf260b* Samsung Top Fridge bottom drawer freezer.
Was thanked: 5 time(s) in 5 post(s)
You really need to take it off a GFI outlet.
