nathaniel.hoffman@gmail.com
#1 Posted : Tuesday, December 25, 2018 6:30:47 AM(UTC)
United States
I have a Bosch she3ar56uc/08 dishwasher that won't drain completely.
It does drain, so I know it's not clogged, and if I run the start of a new cycle for a few minutes it clears the water out of the bottom.
For a while it was not running a full cycle -- it would switch to clean after 10 minutes or so... not sure if it's still doing that. But the last time I ran it, there was soapy water in the bottom after what seemed like a full cycle.
I've had a Sears repairman and local repairman look at it and they suggested:
1. adjusting the high loop (did not work)
2. replacing the door latch (did not work)
3. replace turbidity sensor (nope)
4. replace controller (nope)
5. I also accidentally ordered a replacement control panel, but that did not fix it either.
So I've got $150 in "labor" in this plus I've bought and installed all of these parts myself (over $300 in parts).
What else could it be, or should I just suck it up and buy a new dishwasher at this point?
And also, I feel like both repair guys did not have any clue what to do to fix this thing... is that normal?
Thanks,
Nate
