needing some advice, have an older model but it still ran great up until this summer. Had horrible grinding noise last year--and then it stopped spinning this summer--yes I know we should have addressed it earlier but that didn't happen. fast forward to now--we have replaced the shift actuator, basket drive block, gear case and now the motor drive---the thing still does not spin or agitate--it will run through the cycles fine-- and after we replaced the motor drive the only code that I still get is the F7 E6--which is the motor drive.. I will sat that my husband did not check the new motor with that ohm meter--he did recheck all the connections to make sure they were secure ---so I'm at a loss--is it time for a new machine?? ugh I hope not --any help would be great--thanks Robin M.
