I was having issues with freezer not going into the defrost cycle so I ordered a new heater. While waiting for the heater I decided to check the current heater and defrost thermostat and both were showing continuity so I purchased a new control board. Replaced the board and still no defrost cycle. I can manually force the defrost by unplugging the unit, turning the thermostat off and then plugging the unit back in. Does this mean the new board is bad or could the defrost thermostat still be the problem? Thanks for any advice. Bryan
