Issue started with fan not shutting off after several hours. Turned off breaker for 1 minute and got error code F1 F3 EO Per the forum I replaced the upper oven sensor. Oven started for about 5 seconds, stopped and received same error code. Tried power re-set and still get the error code.
I did replace the control board about 5 years ago.
