Was not dispensing ice from bin (plenty of ice available). Discovered Drive Cup was damaged and replaced. Then the auger motor would start intermittently when lever depressed, but would only run for 1-2 seconds and stop. No ice was dispensed, but motor may not have run long enough. Water through door would still work until next day and now water does not dispense either. Can't make auger motor run. Going to check if voltage to auger motor when lever depressed. This machine offers cubed or crushed ice.
