Trying to install a GE soap dispenser. I've taken the door off and taken the lower screws of the door out and slid off the hinges. I can't get to the upper screws because the control panel attached to the top of the door is blocking it. The panel appears to be attached by plastic latches that fit into holes on the door. I tried to pry it out but already broke a piece of the panel. I don't want to break it but I can't see any other way it is attached and can't get the screws attaching the upper hinges so I can slide off the door piece and get to the soap dispenser part. I've attached a pic since this part is not attached in any of the tutorials I've seen. JasonBam attached the following image(s):
