refrig. had water dripping and in the bottom.found freezer drain clogged with ice. thawed out. this was 4 days ago. i now have ice forming around vents in refrig. section and water dripping. the glass shelves seem to be wet also. there is some water in the lower drain pan. any ideas? thanks
