The fridge is running warm. Front display temp is not accurately representing the inside temp as the inside temp starts to raise but the front will still show coolest setting. If I unplug it and plug it back in the display will then show the correct temperature but won’t cool the fridge efficiently. I tried a diy to see if the fan was frozen. Took everything apart, fam wasn’t frozen. The coils and heater were frozen so I defrosted them with a air dryer. Reassembled it and everything seemed to be back to normal. I got the temp back to 4 degrees Celsius and it seemed to hold it for a while. Then overnight it raised again. Please help lol
