OUR WHIRLPOOL DUET 4.O WITH SPIN FRESH FRONTLOAD WASHER WFW9150WW02 HAS TERRIBLE VIBRATION. hAVE LEVELED IT, ADDED A PIECE OF 1 INCH DECKING ON TOP OF ORIGINAL FLOOR TO MAKE SURE FLOOR IS STABLE. tHE MACHINE HAS 2 SPRINGS ON TOP OF THE TUB AND ON THE BOTTOM IT HAS 2 SHOCKS ON THE LEFT SIDE ( IF YOU ARE LOOKING AT IT FROM THE FRONT OF MACHINE ) AND 1 SHOCK ON THE RIGHT SIDE. THEY ARE ALL LEAKING OIL FROM THEM SO I AM SURE THEY ARE WORN OUT.
mY QUESTION IS CAN I PUT 4 SHOCKS ON THE MACHINE, THERE ARE PLENTY OF MOUNTING HOLES IN THE OUTER DRUM AND ALSO THE BOTTOM OF THE MACHINE FRAME TO ACCEPT THE SHOCKS. wOULD THIS CAUSE A PROBLEM OR POSSIBLY HELP IT STABILIZE BETTER WHEN SPINNING ?
tHANK YOU
