Sergei_K
#1 Posted : Monday, February 12, 2018 2:34:36 PM(UTC)
Sergei_K
I have Frigidaire Gallery dishwasher. It gradually stopped washing dishes and started spraying a thin layer of grease over everything. I cleaned filters & sprayer arms, checked the float (continuity in on/off position is fine and it goes up& down with no obstruction), ran dishwasher through several cleaning cycles with soap and vinegar and replaced a water inlet with a new one. It works a little better but still 1/2 of dishes come out with specs of dirt that were not on them when I put them there, some of the dishes get a grease film, but not all. Also, usually only about half of the soap gets used up, regardless whether I use a tablet or pour liquid dishwasher solution, whether I put them in the soap container or toss on the bottom. Could you recommend what else to check or suggest what might be causing the issue? Can it be that the drain pump drains more than it is supposed to?
Thank you,
Sergei
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
#DW80F600UTS Samsung Dishwasher High Temperature Heating Error (Dishwasher Repair)
by Guest 1/24/2024 6:35:24 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
KDTE554CSS3 Dishwasher (Dishwasher Repair)
by olderwhite@yahoo.com 1/13/2024 10:34:56 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
