GE Washer Squeaky in Agitation cycle
My hydro wave washer started squealing, squeaking, and banging during wash cycle with heavy clothes. Looked on this forum and found the sagging issue. Took the front panel off my washer, started a load and discovered that the noises were coming from two tabs under the frame that holds the motor were rubbing on the bottom floor of the washer. Since these tabs appear to serve no purpose, I simply bent them towards the sides of the washer and now I have 1/4 inch clearance with a full load of comforters. NO more noises! I had already ordered the updated skirt to fix the sagging issue, but I doubt I will install as long as I still have adequate clearance around all components. I also made sure the cement weights in the back were secure while I had the front off. Whole job took me about 15 min. Could do it next time in 3 min.
