Plastic in my washer
thanks so much for the help. I removed the agitator and found that the tub had broken off from the part that makes it spin The T nut will not come off since the part below the nut spins (tub broken off from the part that makes the tub spin).
I found the plastic is coming off from the plastic ring under the tub.
This is happening since the tub was hanging off it dug into the plastic a little bit. Is it worth it to repair the washer or buy a new washer? The current machine is around 6 years old.
