Please Help. Error code 28 references regarding Lock assembly check, removed part Checked oms in part on pin 1 & 3 as directed via manual. Owners Manual trouble shooting guide says is shound read 340oms My Lock switch assembly reads 121 when tested?? (checked 3x's)
Do I need to replace the part due to Low Oms read?? Help!!! Thx Na Na
