washer will run for about 4-5 minutes, and then shut down. red cancel light comes on, but nothing will come on after pushing any button. reset the breaker ( not tripped) and I can push the cancel button to turn the unit off. I can push the wash cycle on (but no heat) and the unit works okay. there is a light gray discoloration on the element where it is held by the holding strap. could my heating element be open ( shorted out)
