Hi all, looking for some advice. I have a Maytag washer (legacy series) that wont fill. I of course checked my water pressure, inlet valves( which checked to be fine ) and the water pressure switch seems to be good.( has continuity and clicks when i blow into it) . I am stumped as to what else could be the issue. There is no "buzzing" noise when I attempt to fill it with water. So it seems no power is getting to the valves. Any input on what else to check is greatly appreciated. Thanks so much!!
I should also mention I hot wire tested the inlet valve and they buzzed as they should so it seems they are fine.
