firstly the front panel showed water filter need replacement, did that, reset the filter. prior to that, the icemaker was building ice up under the icemaker at the ice cube storage tray as if the water valve was not completely shutting off but was still making ice..it stopped making ice and after turning the ice maker on and off, after a bit, the green indicator lite will go from solid to flashing. I replaced the water valve... Now I can feel water entering the fill line but does not fill the icemaker and after turning the icemaker on and off after a bit will go from a solid green light to a blinking green light... thawed the water line entering the freezer compartment. Blew through the line it appeared to be clear though if I blow hard it seems to block the air.. might be my imagination...anyway, thought I was a fairly good troubleshooter. So whatta you think..
