Hello,
I have been searching for a while and can not find a solution to my problem. I am hoping you can help.
My dishwasher has an issue with starting a cycle. What that means is when I select a cycle it will not start the pump. It fills with water and then I can hear a relay click and nothing happens. It will release the soap and will drain and fill back with water. One weird thing is that sometimes it works and sometimes it doesn't. If I put it in diagnostic mode it flashes F6 then E4 several then flashes F- then E- several times. It never flashes any errors during a cycle or stops the cycle.
Research has found articles mentioning an overfill reservoir and others mention flow meter. But I don't think this dishwasher has either of those.
Any help or tech sheets appreciated.
