Takes 45 minutes to preheat to 350. Using conventional Bake settings, Oven light doesn't work anytime.
When using Convection Bake settings, that are on oven settings through the digital keypad, the oven light comes on all the time and goes off when door is open, also oven light goes off when preheat temp is reached.
This oven is not a convection oven, so am confused that the control panel has convection settings.
Microwave turntable currently not working. Sporadically works. The plastic rotator is not broken.
