The microwave has stopped working all of a sudden. When I set the timer and press start, there is an audible click and the light in the oven flickers and nothing happens. The fan and lights work fine and the control panel works as well. I had just finished heating some food and put in a second plate when this occurred. I pulled the plug to reset the unit but nothing changed. I also tested the fuse behind the control panel and it is fine. What am I missing?
