I have a GE washer model GTWN4250M0WS and it won't agitate or spin, checked the lid switch and it is good. No error code in motor led. No error on field service diagnostics. Resetting motor doesn't help. What's left is either motor or the motor control board. GE motor part # WH20X10066. Need wire diagram to test the motor. Anyone has the wiring diagram for the motor? or any idea which wires to apply the voltage to test the motor? See attached motor wire screenshot. Thanks, -don don2828 attached the following image(s):
