This is an LG under the cabinet microwave. It has stopped heating. The door operation seems correct. The microwave runs fine, but it will not heat anything.
I am leaning toward a bad diode, because I think a bad switch would prevent it from running.
Is this a correct assumption, or should I look at the switches?
