My Samsung front load washer has excessive wobble during spin cycle to where the machine shuts off then restarts the spin cycle again whether the load is balanced or not. I bought and replaced the 4 bottom shock dampeners from your website with no success. The machine is level. Not sure if this is a mechanical or electrical issue. Debris filter is clean and drains normally. Any ideas or similar experiences?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Two possibles here. 1. the support arm (spider arm) shaft assembly which is part ID 7-4 on the parts breakdown. Samsung DC97-16509C Assy Flange Shaft;grace, - AppliancePartsPros.com 2. it may be your bearings on the drive shaft are bad. Parts #: 6601-002516 rear bearing (not available even thru google search) Parts #: 6601-002632 front bearing (not available even thru google search) Parts #: DC62-00156A seal
Originally Posted by: brobriffin Two possibles here. 1. the support arm (spider arm) shaft assembly which is part ID 7-4 on the parts breakdown. Samsung DC97-16509C Assy Flange Shaft;grace, - AppliancePartsPros.com2. it may be your bearings on the drive shaft are bad. Parts #: 6601-002516 rear bearing (not available even thru google search) Parts #: 6601-002632 front bearing (not available even thru google search) Parts #: DC62-00156A seal Thank you for the reply and information.
