GP38-2
#1 Posted : Wednesday, September 7, 2016 6:24:00 PM(UTC)
GP38-2
This washer stopped in the middle of cycle. Now it will fill, then nothing. The motor does not even hum. Just sits there after filling. Water level selector switch working properly. Transmission and belts are fine. Nothing stuck between inner and outer tub. Don't think it's a lid switch issue as the fuse is still good. Thinking maybe motor or timer. How would I narrow it down? Any other suggestions? Thanks
cbmserviceguy
#2 Posted : Thursday, September 8, 2016 8:16:24 AM(UTC)
cbmserviceguy
The lid switches on these units are a known issue. They do not always blow the fuse. It depends what failed. There is a lid switch and a check switch. Take the top off the washer and ohm the switches. Below is the kit to fix it. It comes with both switches and such.
Whirlpool 12001514 Switch Assembly with Fuse - AppliancePartsPros.com
GP38-2
#3 Posted : Thursday, September 8, 2016 5:39:21 PM(UTC)
GP38-2
Thanks very much! Good to know. I was thinking if either the lid or check switches were bad, they would blow the fuse. Is there a trick to getting the top completely off? I'll ohm them out and get back. Thanks again!
GP38-2
#4 Posted : Wednesday, September 14, 2016 9:18:09 PM(UTC)
GP38-2
Switches were good, but the spring loaded switch activator was binding.
cbmserviceguy
#5 Posted : Thursday, September 15, 2016 3:54:48 AM(UTC)
cbmserviceguy
They have a complicated design as far as lid switches go. That's why they tend to have a lot of issues. Glad to hear you got it all figured out!
