Kitchen Aid Superba microwave will not heat. Everything else works, the turntable, crisp, convection oven. Replaced the magnetron and magnetron thermostat and diode and the 20 amp fuse. checked all the remaining thermostats and high voltage resistor and door switches. All are ok. Replaced the main control board still no heat when microwaving. Suggestions??
