I have a 5 year old GE Microwave. It is sitting above the range/oven. Recently when the oven is in use, Microwave gives the error "Steam sensor error". This seems to be caused by the heat rising from the oven. The microwave does not work until the oven below is cooled down. Then I have to unplug and plug the MW to make it work.
Is there a sensor that can be changed in the MW?
