AppliancePartsPros.com
Appliance Repair Help
Washer Repair
inlet valve no voltage but pressure valve works
right in the middle of a fill the water stopped filling the tub.
water from the wall is good neither cold nor hot come in no voltage on either inlet solenoid, 400-500 ohms on both
the inlet valve is not getting voltage during wash but if I put water in manually everything works. I put water in. Close the lid and it starts right up until it needs water again.
Washer Repair
