Hi Guys After my previous post I decided to pull the machine apart. Ive tested all the sensors I could find, all seem good apart from B1/10. The only problem is I cant reset the fault code to run it through its cycle to confirm. I have seen on various sites you have to press a combination of buttons, Ive tried all the ones Ive seen and none of the combos seem to work.
PS Ive contacted Miele Germany/UK/USA, they will tell you nothing!! All I had was three sets of contact details for Miele Techs.:mad:
I believe I may have some Miele service manuals. I will do some searching to see what I can find.
Ok, the only two Miele manuals I have at this time are...
T1500 Miele Dryer.pdf W1900 Series Miele Clothes Washers.pdf
Maybe another tech will be able to locate one and share it with us.
Thanks for trying, as much as it pains me I think I'm gonna have to call someone in,
Hey, I have had a stroke of luck, I found a Miele tech who is not worried about the cast iron secrecy agreement Miele have. He emailed me a diagnostic sheet which has given me the solution to my issue. If you would like to give me a email I can forward it to you for your future reference.
Cheers
Dan
Hey would it be possible to send me the diagnostic sheet, i have a G7856 dishwasher stuck on a boat in the middle of nowhere with fault code F-- and manual says i have to call service agent. Would be greatly appreciated. Many Thanks Op. eto.galileo@gmail.com
