i don;t know if my first message went through so here i go again I purchased a water level switch part #AP2045895 is there an adjustment screw? it is not working.
[FONT='Times New Roman'] No, there is not adjustment on this switch. Was you original problem washer overfilling? If so the problem is that the tube that runs from the water level control to the tub is stopped up. To check this remove the front and look at the left-hand side of the tub you should see the tube remove it. Look in the end of the tube to see it is stopped up. If it is you should be able to clean it out with a toothpick. Clothes Washer Repair Guide[/FONT]
yes it would keep filling up. when the repair man came he blew into the tube and it worked for one wash but not rinse cycle
