[QUOTE=fairbank56;880746]I would suggest replacing the lid switch. The middle wire is the ground connection for the cabinet. Without the lid switch connector plugged in, you won’t have a good cabinet ground which means you have two safety violations. 1) no lid switch, 2) no cabinet ground.
Eric[/QUOTE]
Eric,
Thanks for the info about buying a new lid switch. However, because of my past lid switch bypass, one wire of the connector (that I used to make the jumper) is now corroded. How do I clean it so I can use it when I buy a new lid switch? Thanks so much.
